Hi,everyone! Help me, please, with my problem! i'm working in Keil C251 compiler. i have to use assembler code into C code and i found in C251 user's manual directives "#pragma asm/endasm". but i can't compile this. compiler writes: " 'asm/endasm' requires src-control to be active ". May be i must to do anything for working with asm/endasm directives, what i dont know. Or may be i'm in wrong way. Please, help me! Gennady.
See the Thread "How to compiler (sic) *.src file?" Look up the message in the Errors help file (click on the message in the build results window, then press F1). You need to use the command-line option (or uVision option) to tell the Compiler to generate .src. See the C251 manual documentation on "#pragma asm/endasm
