finding recursive calls
Has anyone written a tool to help track down recursive function calls? I'm sure many of us have seen the dreaded C51 linker warning above recursive calls.
My problem: I just spent 30 minutes sifting through someone elses code trying to find the actual culprit that produced the recursive call linker warning (no function pointers in the code, so I was pretty sure the warning was real). It turned out to be about 4 or 5 function calls deep pass the function it warned about. Not a difficult task to do by hand, but....
I'm sure that the map file can be used to create a call tree, but I believe you'd have to create the call tree manually. It seems that that it wouldn't be that difficult to write a program that will parse the map file and tell you all the functions involved in a specified recursively called function. If it doesn't exist, maybe I'll be bored enough to actually write it someday :)
-nelson
