hi, i am using uVision2 V2.03 with PC Lint. does anybody know how to set up uVision2 to get the messages from Lint into a text file as well as into the build window. I'd appreciate any form of help or comment. Thanks in advance!
You can direct uVision to record everything from the Build window to a logfile by specifying "-o filename" on the command line See the "Getting Started" guide; it's Chapter 12 in the 8051 version, GS51.pdf
Take a look in the following support database. http://www.keil.com/support/docs/1835.htm
