Hi I want to interface a serial EEPROM over the SPI Interface to an Atmel 89S53. Does anybody have some Source Code to do this. My doesn't work! For the EEPROm I have first to transmit the write enable instruction and after that the write command the address and the data. In my Code the Clock stops after every Byte. This is wrong. Why does this happen? Thanks for help Christian
Have you searched the Keil knowledge base, samples, and the Vendors' websites?
Thank you! It works yet!
