RTX51
I created three tasks. Each task increments a counter and send it to LCD by using a semaphore. I used timer 0 for system tiks. I used timer 2 to interrupt every 1/2 second and increase the counter. Also I used ext INT1 to do the same.
Now if I eliminat os_start() from my code timer2 and ext INT1 works fine.
I made the interrupt to send count to LCD.
If I include os_start(), neither Timer2
or ext INT1 works. I made the interrupt to increment a global counter and let the tasks to send it to the LCD.
However, I duplicated timer 2, ext INT1 initialization and IE before for(;;) loop in each task and the timer2 and ext INT1 still do not work but the tasks work.
