I have four object files created by C51 compiler, one of them RTXCONF.obj. I'm not using banking. I used the commnad: 1)L51 f1.obj,f2.bj,f3.ob,f4.obj To f.abs 2)L51 f1.obj,f2.obj,f3.obj,f4.obj,RTX51 To f.abs in both cases I got the same error: Fatal error 234:use RTX-51 SWITCH. Anyone knows what missing Thanks
Try this:
L51 f1.obj,f2.obj,f3.obj,f4.obj To f.abs RTX51
Jon, I suppose the answer to this question should be, "Please read the manual," but if you do consult the manual [1], it says: 234 USE RTX251 OR RTX51 CONTROL The application uses RTXx51 tasks mented. Could you explain what that's supposed to mean? ;-) Also, why isn't this error (or any other Linker error >124, for that matter) in the online errors help file? The manual [1] lists Non-Fatal errors up to 134 and Fatal Errors from 201-251 [1] Macro Assembler and Utilities for 8051 and Variants User's Guide 07.2000
I used BL51 i/o L51 and worked
234 USE RTX251 OR RTX51 CONTROL The application uses RTXx51 tasks mented. Could you explain what that's supposed to mean? ;-) I don't know, either. That's why our technical writer fixed it in the upcoming release. :-) Jon
