I have four object files created by C51 compiler, one of them RTXCONF.obj. I'm not using banking. I used the commnad: 1)L51 f1.obj,f2.bj,f3.ob,f4.obj To f.abs 2)L51 f1.obj,f2.obj,f3.obj,f4.obj,RTX51 To f.abs in both cases I got the same error: Fatal error 234:use RTX-51 SWITCH. Anyone knows what missing Thanks
Try this:
L51 f1.obj,f2.obj,f3.obj,f4.obj To f.abs RTX51
Jon, I suppose the answer to this question should be, "Please read the manual," but if you do consult the manual [1], it says: 234 USE RTX251 OR RTX51 CONTROL The application uses RTXx51 tasks mented. Could you explain what that's supposed to mean? ;-) Also, why isn't this error (or any other Linker error >124, for that matter) in the online errors help file? The manual [1] lists Non-Fatal errors up to 134 and Fatal Errors from 201-251 [1] Macro Assembler and Utilities for 8051 and Variants User's Guide 07.2000
234 USE RTX251 OR RTX51 CONTROL The application uses RTXx51 tasks mented. Could you explain what that's supposed to mean? ;-) I don't know, either. That's why our technical writer fixed it in the upcoming release. :-) Jon
