Compiling with startup code
Hello everyone
I am relatively new to the 8051.
I am running in to problem creating a simple app with the ATMEL89C55.
I created a new project called test and insert 2 files, test.c and STARTUP.A51.
It is my understanding that the STARTUP file is required to reset the memory of the microcontroller. In my test.c, all I have is a printf statement.
When I create the target I get 2 warnings:
***Warning L1: Unresolved external symbol
symbol: ?B_SWITCH0
module: STARTUP.OBJ (?C_STARTUP)
etc...
When I try to run it under the debug mode, it seems to be stuck in an endless loop on the statements:
IF IDATALEN <> 0
MOV R0,#IDATALEN - 1
CLR A
IDATALOOP: MOV @R0,A
DJNZ R0,IDATALOOP
ENDIF
Any help would be greatly appreciated.
Much thanks in advance.
Thomas
  • When I create the target I get 2 warnings:
    symbol: ?B_SWITCH0
    So what's the other warning?
    "Reference made to unresolved external" I'd guess?
    The message means that startup.obj has made a reference to something (eg, a variable) called "switch0" but nowhere in your project actually defines anyhting called "switch0"
    Do you recognise an identifier called "switch0?"
    What do you think it should do?
    Where do you think it should be defined?
    Note that the linker converts everything to UPPERCASE; so your code might actually use "Switch0" or "sWiTcH0" or "SwitcH0" etc etc etc
    symbol: ?B_SWITCH0
