Hello, I have the following problem: I need to know as assigning a position fixed of memory (code)to my functions in C and assembly. Another consultation: When I call to a function from C to assembly, the program doesn't continue running, it enters to a code section without "code" (without routine). How do I make so that when calling a function from C to assembly I make sure him to return to the main program? the routine that I use is the following one: In C: extern void FUN1(void); float a, b; void main (void) { while (1) { FUN1(); a=b*5; .. .. .. } } In Assembly: NAME FUN1 FUNA SEGMENT CODE FUNN SEGMENT IDATA RSEG FUNN DS 2 EXTRN CODE (MAIN) EXTRN CODE (?C_STARTUP) PUBLIC FUN1 CSEG AT 80H FUN1: LJMP WATCH WDTREL DATA 86H RSEG FUNA WATCH: MOV WDTREL,#80H END Thank You....
