Mixed Memory Models
C51 v6.03+; uVision v2.07+
I want to build a Project with some files using the SMALL model, but most using LARGE.
If I select LARGE in the Target options, and specify SMALL in the C51 'Misc Controls' where required, or use a #pragma in the file itself, I get a fatal Compiler error:
RESPECIFIED OR CONFLICTING CONTROL
If I select SMALL in the Target options, and specify LARGE in the C51 'Misc Controls' box where required, everything Compiles OK, but I get Linker warnings for each of the 'Large' Modules:
L14: INCOMPATIBLE MEMORY MODEL
If I specify 'large' in each function declaration where required, it all Compiles and Links OK!
Thus it is possible to create a mixed-model Project, but extremely cumbersome to have to specify the model on every function!
Why doesn't it work when the model is specified at the module level?
(yes, I know you wouldn't want to design a Project like this from scratch, but this is "inherited" stuff...)
