How to link existing OBJs ?
I met the "UNRESOLVED EXTERNAL SYMBOL" problem when I try to build a target in uVision2. The linker can't find the existing OBJ which I don't have the source. How can I send this OBJ file to link with others?
Thanks a lot!
  • When you choose 'Add Files to Group', one of the options in the 'Files of Type' drop-down list is "Object File (*.obj)"
    So you just add the .obj file to your project, and uVision knows to just link it - it won't try to compile or assemble it!
    You might want to create a separate Group called "Object Files" or something
    If your object file name has a different extension (not .obj) go to Project/File Extensions, Books and Environment and add the required extension in the 'Object File' box.
