I am having a difficult time trying to wildcard segments using the following command in the linker options command menu ?pr?*?myfile (0400H) ie. SE (?pr?*?myfile (0400H)) I have alot of funtions in the files and if I type each name out I get a pc shutdown error Does this linker have the wildcard capability??? Any ideas on what my problem is??? Thanks, Jim-
Also when I do explicitly list the function name and file name and I want one function to be loacated next to another the linker ignores putting the second file after the first file specified. ie. SE(?PR?myfunc1?myfile1(0400H),?PR?myfunc2?myfile2) it does not located function 2 after function 1, even though I get a clean link. Any explaination for this ? What am I doing wrong???? I have alot of functions to locate together and they are in different files. I really need a wild card. I am trying to move them around within the CODE class. Thanks for any help -Jim
Any particular reason why you need them in a specific order?
Andrew, I need them all to start above address FF4000H. Right now they are all pushed down in code memory. I still intended to keep them in the code class but at or above the FF4000H location.
I was entering the files into the command window one by one and when the command line gets long, I get a general protection PC fault and I am no longer able to inter segment data, application shuts down.
I think what you really want to do is use the CLASS, RESERVE and SEGMENT directives in the linker. With this you can assign your code to any memory area you want. Check the 251 Utilities manual on how to use these directives. We use these in our program here to allocate the memory space to DATA, XDATA, EDATA, CODE, ECODE and HCODE areas.
If your command line gets too long, use a command input file; eg,
L251 @commandfile
