Floating Point
How can I deny a number floating point without utilizat some mathematical operation?
How can I take the first 8 bits of the number floating point, those but significant (MSB) or the bit but significant of the number type floating point?
  • Here is a routine to print the parts of a normalized float ( except for 0.0 or -0.0 ).
    #include <stdio.h>
    #include "AT89X55.H" // to define TI
    typedef unsigned char BYTE;
    typedef unsigned int  WORD;
    typedef unsigned long DWORD;
    void PrintFloat( float TheFloat )
      union
        struct
          float Float;
        } Whole;
        struct
          //@Float+0
          BYTE Exp1         :7; //bits 6-0
          BYTE Sign         :1; //bit 7
          //@Float+1
          BYTE Significand2 :7; //bits 6-0
          BYTE Exp0         :1; //bits 7
          //@Float+2
          BYTE Significand1 :8; //bits 7-0
          //@Float+3
          BYTE Significand0 :8; //bits 7-0
        } Parts;
      } Float;
      Float.Whole.Float = TheFloat;
      printf( "Float             = %#e\n",  (double)TheFloat );
      printf( "Sign              = %#i\n",  (int)Float.Parts.Sign );
      printf( "Exp Base 2        = %#i\n" , ( (int)Float.Parts.Exp1<<1 | (int)Float.Parts.Exp0 )  - 127);
      printf( "Mantissa Base 2   = %#lX\n" , 0x800000 | ( (DWORD)Float.Parts.Significand2 ) << 16
                                                      | ( (DWORD)Float.Parts.Significand1 ) << 8
                                                      | ( (DWORD)Float.Parts.Significand0 ) );
      printf( "\n" );
    void main(void)
      TI = 1;  //to get debugger to print to serial window
      PrintFloat( -2.3456E10 );
      PrintFloat( 0.0 );  //note!! 0.0 is all zeros plus a sign bit
      while( 1 )
  • Does "Deny" = "Negate"?
    Here is a fast negator.
    *((BYTE*)&TheFloat) ^= 0x80;
