I recently have changed from the Franklin compiler to Keil. From what I can tell I have the settings done and I have compiled INTEL hex code. The problem is this code seems to do nothing when downloaded to the chip, while my old franklin code works fine. Anyone got an idea whats causing thing? Im sure its something not set for the keil compiler. Thanks for any help on this.
I have the internal ram set and that is the address it uses. I can generate a simple Hello world program which works if compiled with the franklin compiler but doesnt work in Keil.
Make sure the code rage is 000F-1FFFH
