Simulation crashes
Hello forum,
I got a problem with the µVision2 debugger. Every time the simulation reaches the statement
T6CON = 0x82C0;
(which means timer 6 runs downward, clocked with 5 MHz @ 20 MHz system clock, toggles P3.1 and uses CAPREL) the µVision crashes.
After a few seconds a requester appears, saying an application error has occured and an error protocol will be made.
uv2.exe illegal access (0xc0000005), address 0x1000464e
(I've got a german Windows NT - the messages are in german, hence the rough translation)
Does everybody knows a solution for this problem?
Thanks - Peter
