An hour ago I installed the last version of this software, then I opened my project and added some files with extension "*.h" I opened them as "C Files", then when trying to close them one of them closed, but I cannot close the others (I opened three of them). I already re-started my computer but I just can't get these files off my project. I right click the mouse over the file select "remove filename.h" and asks If I am sure I want to remove it when I select yes, it does nothing!.
This is, in fact, a very old bug! The 'Remove File' options on the 'Project' menu and the right-click popup menus have never worked! You have to select the file in the Project and press the 'Delete' button
Hmmm. I just tried it (both the local menu and the Project menu) and was able to remove files from a project this way. I'm using Windows 2000, FYI. Does this fail to work, Andrew? Jon
Nope: neither the local menu nor the Project menu works! These are Dongled versions; Same effect (or rather non-effect!) under WinNT4 and Win98SE. Sorry, don't have access to Win2k.
