Hi, Anyone successfully access Temic 89C51RD2's internal EEPROM? I have this unsigned char xdata * data pEEAddr = 1; void WriteOne(unsigned char val) { unsigned char data dVal = val; DisableGlobalInterrupt(); MapEE(); *pEEAddr = dVal; UnMapEE(); EnableGlobalInterrupt(); } Somehow that did not work reliably. I examined the assembler output and it looked ok (one movx instructure between the MapEE() and UnMapEE() macros). Thanks for any insight. Andy
I've had no problems at all with it. My basic routines (which definitely work) are as follow: // To read a single byte from a location in EEPROM. char ReadEEPROM(int addr) { char EEdata; EECON |= 0x02; // Enable EEPROM memory space EEdata = XBYTE[addr]; EECON &= 0xFB; // Disable EEPROM memory space return(EEdata); } // To write a single byte to a location in EEPROM. void WriteEEPROM(int addr, char EEdata) { EECON |= 0x02; // Enable EEPROM memory space XBYTE[addr] = EEdata; EETIM = 0xB8; // Set timing register: 10*Fclk(MHz) = 10*18.432 = 184 = 0xB8 EECON = 0x52; // Send sequence to start EEPROM write... EECON = 0xA2; while(EECON & 0x01); // Wait for EEPROM write to finish EECON &= 0xFB; // Disable EEPROM memory space } Note that in the write routine you must send the special codes to EECON to make the write happen - perhaps you missed this. You also need to tweak the timing register to suit your particular clock speed. Chris
oh,I have the same problem.And in http://www.keil.com/forum/docs/thread477.asp EECON &= 0xFB; // Disable EEPROM memory space I think it should be: EECON &= 0xFD; And the value of EETIM in my system: EETIM = 0x7D; //5*25MHz And In my simulator debug,it will endless in: while(EECON & 0x01); // Wait for EEPROM write to finish so I must put the microcontrol to the board, but can't get right eeprom data operation,what't wrong about it? My emulator micetek Easypack/E II 8052F can't support EEPROM data RD/WR function,so I must download my code to the cpu and run it in board? The cpu is ATMEL 89C51RD2-CM,is it the T89C51RD2? And the programmer is lab tool-48,its software vertion is V4.67,the device of T89C51RD2 for selecting is only TEMIC,I don't know whether they are the same device? I can't get right EEPROM data RD/WR using your means,so could you give me some advice?
