Hi all, In my function, I use local variables, and everything works fine while I stay in C. But when I try to use the same variables in an assembler insertion in the same function, I get error A45: undefined symbol. At the same time, if these variables are declared global, it works. Can anything be done about it? Here is a model of my function: unsigned char between(unsigned char order) { unsigned char hi; hi = order; #pragma ASM xch a, hi rrc a xch a, hi #pragma ENDASM return hi; } void main(void) { unsigned char a,b; b=170; a=between(b); } Michael.
What memory space does 'hi' live in. If large, then it may be in xdata or the compiler may just optimize it into a register. try unsigned char data hi; David
