how cain pass through a pointer's address to a function
I declared different parameters, variables and pointers and I put into in two blocks. I declare and defined function for calculating, saving and checking chksum for both block.
I realised that the compiler give error message when I try to pass through the pointer's address to a function. I tried to use an another pointer to point to the pointer's address but the compiler didn't support it. Has anybody a good idea to solve my problem.
thank in advace
leslie
#include <reg51.h>
#define record 7
#define byte unsigned char
#define word unsigned int
#define dword unsigned long int
//declare funtions
void save_block(byte xdata *start_addr,word xdata *chksum);
word calc_block(byte xdata *start_addr,word xdata *chksum);
bit chk_block(byte xdata *start_addr,word xdata *chksum);
//declare variables
xdata byte par_buff1[14];
xdata word chksum1;
xdata byte dummy1;
xdata byte xdata *rec_buf_start;
xdata byte xdata *rec_buf_end;
xdata byte xdata *wr_ptr;
xdata byte xdata *rd_ptr;
xdata word chksum2;
xdata word xdata **valami;
main()
//valami=&rec_buf_start;
if(chk_block&rec_buf_start,&chksum2))
// do something
if (chk_block(&par_buff1[0],&chksum1))
//do something
else
//do something
for(;;)
//do something
// functions definition
if(*chksum!=calc_block(start_addr,chksum))
return 1; //setb c
else
return 0;
xdata word blsumma;
while(start_addr!=(byte *)chksum)
blsumma+=(byte)*start_addr++;
return blsumma;
*chksum=calc_block(start_addr,chksum);
