Is it possible to work via DDE interface with Debugger? I used sources from app143, but it doesnt work! Some additional info: uVision v. 2.06 (evalution - may be this is main reason?) under Windows 2000 Server.
How do you mean, "doesn't work?" I got it to work, but didn't find it useful. :-(
When I run the programm and try to enter any command, I cant to see any result. It seems that uVision ignore DDE server commands. But where the reason? Please, tell me version of uVision do you use and your operation system. Is it full or evalution/demo?
The DDE Interface works in the moment only on Windows NT. For some reason it is broken under Windows 2000. It will get fixed in the next revision
