using idata
hello there.....
my name is hardian, from indonesia
i wrote some code using keil.
the code is :
idata char nim[14] _at_0x00 ;
// i read from the keil textbook (the blue one)
but when i compile it, there's an error message:
missing ';' before '_at_0x00
can u tell me why this is happened ?
or, what should i do with the code ?
thanks very much...
sincerley,
hardian
  • idata char nim[14] _at_0x00 ;
    You need a space before and after the _at_ keyword. Re-written for correctness:
    char idata nim[14] _at_ 0x00;
    Yes the idata goes in between the char and the nim if you want to be current with Keil C51 although idata char nim will still work.
    - Mark
    - Mark
