Interrupts with internal and external code
I set the compiler to save the PSW and put it into source mode (4 byte frame) instead of
binary. Now when I load my program into the dscope it has the correct ljmp instructions to my
ISR's. I created an endless while loop(while(1);) in one of my subroutines(external code
space). When I run my code to this location it gets there fine, but when an interrupt occurs I
vector to the ISR and return to the code however when I return I do not actually execute any
instructions or stop at any breakpoints set. The trace shows that I just run through all of my
instructions until execution stops.
One other thing I noticed that the display of the call stack shows a different address than
what should be when an interrupt occurs. It seems to be off by 1 byte. Does this mean
anything the interrupt seems to come and go alright when it hits when I am in my main routine
(located in the same code segment as the ISR) But the stack addressing anomally applies.
