When I load my code into the dscope debugger I do not get a jump to my interrupt service routines in the vector table. I am using two interrupts (serial interrupt -4, timer interrupt -1) The code at location FF000b is FF000b cmod3 (0xff),r2 FF000d rr a FF000e mov r4,a I replaced with ejmp ?PR?Timer0_ISR It goes to the service request but the stack is not correct and the ISR does not return. I get something similar with my serial ISR. Why isn't the linker using the proper jump instruction, or am I doing something wrong?????.
I would like to add that half of my code Main is in processor space and other code is in external memory. ie FE0000-F7FFFF address space. Can the interrupts handle being called from this space and then find there way back home???? ISR is in FF:1000 space (on chip)
Did you write your code in C? How did you declare your interrupt service routines? Jon
Jon, The routines were all written in C and I have 2 ISR's void timer0_isr (void) interrupt 1 using 1 void serialIntr (void) interrupt 4 using 3 They were located in the 251 in the 251 internal address space by setting a segment in the linker setup. I wanted some of my code to be in the internal and some code to be in the external spaces. It appears that when I inline assemble a ljmp or ejmp to these ISR's that as long as I stay inthe internal memory they seem to go back and forth corectly (even though the call stack display shows the wrong return address.... but when I go out into external memory and get an interrupt I don't sequence correctly.. Any Ideas or suggestions... Thanks Jon
What step of the 251 chips are you using? Also, which device? Intel or Atmel WM? Jon
