I am running a piece of code that has ISR's (ie timer, serial) When I generate interrupts.. say by writting to the SBUF register I get the data in the SERIAL I/O window and it shows an interrupt occurred.. but my program does not vector to the ISR. What could be happening. I have all the interrupts enabled.
Without "piece of code" no ideas. Also, where you test ? - in dScope simulator ? - target board with MON251 ? - target board with ICE ? - target board with x251-chip ? If your code true (all interrupts enabled, etc...), there is only one reason why serial-ISR don't vectored: - your program stay (or clear RI/TI before RETI) in another higher-priority ISR.
