USERSTACK in XRAM
I've put the USERSTACK in XRAM (C161 internal ram, 0xE000 to 0xE800) (cf AN Keil APNT_124 + U3 directive).
The project work well and execution speed is improved (local variables in XRAM!).
But, there is still a problem when working with the remote debugger under µV2 (MONITOR).
It only works the first time after downloading the code.
I need to restart the target after each break.
Is someone overcome this problem ?
(perhaps modifying monitor code like STARTUP modifications (cf release.txt §3.5)
Gilles DUPLAY
