This declaration const char code* const gBuildDate = __DATE__; gives lots of link errors when I use RTX51 Tiny but is fine without RTX. (My program uses conditional compilation to build either a RTX or non-RTX version) Any ideas?
This always works for me:
// In each module static const char s_moduleInfo[] = __FILE__ " modified " __DATE__ " at " __TIME__; // Or in one module that is set to "always build". const char g_projInfo[] = "Project modified " __DATE__ " at " __TIME__;
What link errors?
const char *pVar; // pVar can be modfied but not what it points to. char * const pVar; // pVar cannot be modified but what it points to can. const char * const pVar; // Neither pVar nor what it points to can be modified.
Ok Ive realised whats wrong - I was running out of DATA space. If I change the declaration to this const char code* code gBuildDate = __DATE__; its OK. I expected since the pointer was 'const' it would automatically go into code space but apparently not, you have to use 'code'.
