uV2 Locks when exiting debug if set to accept data via COM port
uVision2 v2.10
When I include the following in my debug.ini file, everything works OK
(properly receives data via COM1) until I attempt to exit debug mode,
at which time it locks up . . . have to ctrl-alt-del to shut down uV2.
MODE COM1 9600, 0, 8, 1 /*9600 bps, no parity, 8 data & 1 stop bit*/
ASSIGN COM1 <SIN >SOUT /*ASC output & input is done with COM1:*/
STIME = 0 /*ignore timing of simulated ASC interface*/
  • If you're running Windows NT or 2000 you can just use task manager to kill the hung uVision and restart it. Much faster than rebooting. If you're running Win9x, well...
    I remember something similar one time when I fiddled with the UART but I forget the solution (oh and I did solve by gum). For kicks, make sure uVision is the only program running and see if that makes a difference. I've noticed that uVision hangs sometimes if MS Outlook '97 is running.
    - Mark
    - Mark
