Parsing Library Module Names
I'm trying to debug the following line of code and I'd like to know what the prototype of ?C?CLDOPTR looks like and get a brief description of this library function. Does anyone know what CLDOPTR stands for and what parameters it takes? I'm using the Keil C51 compiler v5.50e
-dean
1964 1 byStoredChksum = *((BYTE *)&psDest->status + 1);
; SOURCE LINE # 1964
005C 900000 R MOV DPTR,#psDest
005F E0 MOVX A,@DPTR
0060 FB MOV R3,A
0061 A3 INC DPTR
0062 E0 MOVX A,@DPTR
0063 FA MOV R2,A
0064 A3 INC DPTR
0065 E0 MOVX A,@DPTR
0066 247E ADD A,#07EH
0068 F9 MOV R1,A
0069 E4 CLR A
006A 3A ADDC A,R2
006B FA MOV R2,A
006C 900001 MOV DPTR,#01H
006F 120000 E LCALL ?C?CLDOPTR
0072 FF MOV R7,A
;---- Variable 'byStoredChksum' assigned to Register 'R7' ----
  • Why not see you have a C error first? When checksumming a struct, why not just:
    typedef unsigned char U8;
    U8 *ptr = (U8 *) &psDest;
    byStoredChksum = 0;
    for (idx = 0; idx < sizeof psDest; ++idx)
        byStoredChksum += *ptr;
        ++ptr;
    This will be much easier to debug at the asm. level. Note I've separated the ptr incr. from the dereference. Watch what happens if you combine the two steps (i.e. *ptr++).
    - Mark
