cannot figure out this link warning
I am using 5.20 if it matters
I have a function that is indirectly called from an array of functions. This function is contained in its own module. When I link, I get the following warning:
WARNING 16: Uncalled Segment, ignored for overlay process
segment: ?CO?FACT_CON
in this module I have one variable that I define as
static float code ideal_values[LAST_POINT] ={
if I change the "code" to "const" (or remove it entirely), it will link with no warnings, but now the variable is taking up XDATA, and with only 2K of it, XDATA is VERY precious...
I've also tried several other incantations of the same line of code. It either ends up in XDATA, or gives me the warning.
I've had this problem in several other places, but until now, I chosen to ignore it... any ideas? (if anyone thinks more info is needed, please ask, I just didn't want to flood the list with things like link maps, and other such things)
