Intel Hex - Tool to fill unused bytes?
Is there a way inside or outside of uVision2 to fill my output intel
hex file so that unused bytes are set to 0x00? So that when
I actually program my chip I am sure that every byte is programmed.
  • Usually this option exist in chip-programmer software.
    Also, you can convert *.HEX to *.BIN
    using HEX2BIN utility with option /Pn - pad data, n=0.
    Then load *.BIN as binary data.
    If you still need *.HEX format
    you can convert resulting *.BIN to *.HEX
    using BIN2HEX utility.
