Interrupt and global variable
Hello!
I've an Timer-Interrupt Routine (timer 3 with reload) with will
served every 10 ms!
In this Interrupt-Routine, I send 2 Messages via the CAN Interface.
Now, I send the second message straight after the first, and the problem
is, that the second message won't send in a 10 ms rhytm but often
longer (up to 400 ms!).
Now I use a global variable, where I decide which message to send;
when the value is 0, send the first message, und change the value to 1,
then send message 2 and set the value to 0 and so on!
I declared an int (I also tried unsigned int, char ...). I have set the
value of the variable to 0 in the "main" function, but in the Interrupt
Service-Routine, the value ist "FF", and when I try to change to value
inside the Interrupt-Service Routine, it has no effect!
Is there any other way to transfer data between th "main" and the Interrupt
Routine?
THX in advance!
Have a nice day!
SVEN
