C language
Hi all,
I'm new to this Keil product [µVision]
where can I learn C to write a program in µVision?
regards,
MB
  • It's basically ANSI/ISO C, with some extensions.
    For one, you must use sbit, sfr, or sfr16 to access bit, byte, or contiguous 2 byte registers in the 8051.
    You can disable integer promotion (a good thing) and enums only require 8 bits if they can fit in 8-bits, 16-bits otherwise.
    Functions are not reentrant by default. You must add the keyword 'reentrant' to functions that recurse or are truly reentrant.
    Interrupt Service Routines are declared as:
    void isrUart(void) interrupt UART_VECT using REG_BANK_1
        // code
    You don't have to specify a register bank and you must #define UART_VECT to match the 8051 UART vector number.
    - Mark
  • Try Keil's reference 0-13-753815-4 Schultz C and the 8051
