Does anybody know how to adapt C-files composed under TASKING to be used with KEIL? There are some differences in certain operators. It seems that such a soft should exist? Michael.
This is why I recommend that you should always encapsulate all your compiler dependencies in #defines. Then, you know that you have only one file to modify if you change compilers!
This is why I recommend that you should always encapsulate all your compiler dependencies in #defines Everybody does that, don't they? Erik
"Everybody does that, don't they?" Only after they've finished tending to their aerobatic pigs...!! ;-)
Unfortunately not; eg, see http://www.keil.com/forum/docs/thread2836.asp
