Please Help How do i use Uvision2 for debuging serial comm interrupt routine. I have wrote some code but i must hit RI bit on the serial per. menu to watch the serial INT in progress can it be done automaticly using the serial window ?
You can simulate the serial input in the serial comunication window in the Windows menu. You must run your code, active the serial comunication window and press a key to simulate a serial input from your keyboard.
