I try to debug my program using dScope. My RAM is starting from 0x100000 address and has size of 1MB. I load monitor from 0x1FE000, and set interrupt vector table from 0x100000. After loading executable file, which is mapped from 0x100000, I set PC = 0x100000 and run step by step pressing <F10>. After first step the program come on next command: DISWDT. Next step is not executed and I receive the monitor error 9: CANNOT WRITE BREAKPOINT VECTOR How I can debug program on boards without RAM on 0 address?
Why don't you say to DScope it should use the ChipSelect for your RAM for adresses from 0x0 .. In my case the Flash-CS points to 0x0 .. 0xFFFFF and the RAM-CS points to 0x100000 .. 0x1FFFFF. If I use the debugger I use a "start.a66" where CS1(RAM) starts at 0x000000 ("config.inc": BUSCON1 0x000000 too and monitor starts at 0x00A600) and if I make a File for Flash-Download I use a "start.a66" where CS1 starts at 0x100000. (of course you have to use for those 2 versions 2 different target-configurations!) Maybe it's a little bit dirty but it works fine :)
