Has anyone found a way to pass 2 dimentional arrays to a function? My arrays are stored in code and I need to pass them to a function to display them. Gary Martin
This is really a C question, see: http://www.eskimo.com/~scs/C-faq/q6.18.html - Mark
Without testing, the code below should work: // Data int array2d[5][5]; // Function Prototype void func(int ** pArray2d); // Main function void main(void) { func(array2d); } void func(int ** pArray2d) { pArray2d[0][0] = 3; pArray2d[0][1] = 4; // etc... }
You would thing so, but try doing with Keil. GAry Martin
Yes it should, but it dosen't. Gary Martin
Yes, Without testing, it works. But when tested it doesn't.
unsigned char _2d_array [5][5]; void func (unsigned char (*x)[5]) { x [0][0] = 1; x [1][0] = 6; x [2][1] = 12; } void main (void) { func (_2d_array); while (1); }
Whoops, you are quite right.
