I am interested in using the "slog" command to send the serial data to a file, I tried several invocations and none seemed to work. There is no reference to "slog" in the help index. Could someone tell me what the syntax is ? Thank you in adavance. Eric
SLOG is described in the µVision2 Debug Commands help file - which should be accessible on the Documents tab of the Project window. Failing that, it's on the CD: Keil\c166\hlp\dbg166.chm
