Monitor 251
Hi guys,
I'm facing problems in making the Monitor 251 terminal program to communicate with corresponding target program. I'm using the Rix51 board by Rigel Corporation. I've tried my best to configure the Install.A51 Configuration file but everytime it gives me the same error "Target Device not found. Check the baudrates etc.."
The configuration which I want is that my Monitor program should interact with the Rix51 board through the external UART. As far as the impression I got after looking into the Configuration file is that the External UART (SIO ??) is configured for the MCB51 evaluation board. If what I'm assuming is correct then do I have to modify the entire configuration file to make it work with the Rix51 board. If anybody has any experience related to this can you please show me some light.
Regards,
Vipin Mehta
