combine two hex file ?
How can I combine two hex files as one to code memory so that the first part starts from 0x0000 and the other one from 0x8000 to 0xFFFF? I use P89C51RD+ and Keil uVision 2. Is it possible to add one hex file to project beside c-code (start from 0x8000) and compile it to one hex file?
  • How can I combine two hex files as one to code memory so that the first part starts from 0x0000 and the other one from 0x8000 to 0xFFFF?
    Use a TEXT editor to combine the files. Open your editor and load the first file. Delete the following line from the end of the file:
    :00000001FF
    This is the Intel HEX File EOF Record.
    Insert the contents of the second file after the EOF record you deleted.
    Keil Support
    :00000001FF
    Keil Support
