I need the 'TZ' variable be set for RCS version control system. But when i set this env. var, UVision2 "refuses" to build any project, it always REBUILDS ALL :(. So, the question is: How i can get the value for 'TZ', suitable for UVision2. (I've tried to use the string from the Windows Control Panel | Date&Time, but it doesn't help) Thank you
Thank you, but... I've read these documents BEFORE i post my question. It didn't help :) May be you have any other suggestions?
http://www.keil.com/support/docs/1418.htm
