Hey guys, ı am new at embedded programming and ı am following a video course on udemy. In that course the lecturer using open stm32 system workbench based on eclipse and ı am using keil. in the course we will create an specific header file. For that the lecturer creating a project in eclipse with no firmware package i.e only startup files exist. And ı am trying to create the same project on keil so in manage run time environment ı am selecting Startup and CMSIS: Core. But in my project the specific header file is already exist (You can see from the image below). How should I create my project?
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/471/udemy.jpg
AliRizaDenenPezevenk said:In that course the lecturer using open stm32 system workbench based on eclipse and ı am using keil
Why on earth would you do that?!
I would strongly recommend that you use the same tools that the instructor is using!
Trying to follow the course using different tools is just going to unnecessarily confuse the issue - as you have found!
The Open STM32 Workbench is free - there is really no reason not to use it!
Once you have successfully completed the course, then you should be in a position to try different tools.
When you reach that point, start here:
http://www2.keil.com/mdk5/learn
http://www.keil.com/books/
