Create standalone function to be loaded into Code memory
I have an application, for an 8051 device, that accepts commands, acts on them, and provides a reply.  I want to implement a command that will load code (for an new function) into a reserved section of Code memory so that the code will run when a different command jumps to it.  I'm having trouble getting the standalone function, which needs to access data arrays and other functions in the main application, to link (BL51 linker) without warnings.  My test function is:
void Cipher (unsigned char *in, unsigned char *out);
extern unsigned char xdata Data_Bffer[];
extern unsigned char xdata PlainTxt[];
void User1(void)
	PlainTxt[0] = 0x06;		//ASCII "ACK"
	PlainTxt[1] = 0xAA;
	PlainTxt[2] = 0x55;
	PlainTxt[3] = 0xAA;
	PlainTxt[4] = 0x55;
	PlainTxt[5] = 0xAA;
	PlainTxt[6] = 0x55;
	PlainTxt[7] = 0xAA;
	PlainTxt[8] = 0x55;
	PlainTxt[9] = 0xAA;
	PlainTxt[10] = 0x55;
	PlainTxt[11] = 0xAA;
	PlainTxt[12] = 0x55;
	PlainTxt[13] = 0xAA;
	PlainTxt[14] = 0x55;
	PlainTxt[15] = 0xAA;
	Cipher(&PlainTxt[0], &Data_Bffer[0]);
	return;
and the project also contains the following assembly code file:
$NOMOD51
PUBLIC   Data_Bffer
PUBLIC   PlainTxt
PUBLIC   Cipher
Data_Bffer   EQU   0DE0h
PlainTxt   EQU   0FF0h
Cipher	EQU	2104h
END
where the addresses for the data arrays and the function Cipher are taken from the .M51 file of the main application.  I'm getting warnings like the following from the linker:
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
    SYMBOL:  _CIPHER
    MODULE:  C:\Users\R\UserFunctions.obj (USERFUNCTIONS)
    SYMBOL:  ?_CIPHER?BYTE
My Assembler, Compiler, and Linker command lines are unaltered from the defaults (in the Silicon Labs IDE); e.g. linker command line is:
RS(256) PL(68) PW(78)
If I change "Cipher" to "_Cipher" in the Assembly file, then the first warning goes away.  But I don't know what to do about "?_CIPHER?BYTE".  Anyone tried something like this before and know the fix?
