I created a project with the Keil MDK and then configured and initialized the microcontroller of ST via the STM32CubeMX. I then tried to compile the generated code with Keil MDK. However I get the following error message : .\RTE\Device\STM32F413VGTx\STCubeGenerated\Inc\stm32f4xx_hal_conf.h(236): error: #5: cannot open source input file "stm32f4xx_hal_exti.h": No such file or directoryIn the directory C:\Keil_v5\ARM\Pack\Keil\STM32F4xx_DFP\2.13.0\Drivers\STM32F4xx_HAL_Driver\Inc this file is missing.Does anyone have a solution?Software used:uVision v5.27.1.0Keil::STM32F4xx_DFP v 2.13.0
Hello, I did a simple test, and I find this file in ..\Inc relative to the generated .uvprojc file.
Thanks for the answer,
I can only find the file in the STCubeGenerated. I copied it manually into the Include Path. Then I get the application compiled.
But shouldn't the file also be included in the Keil STM32F4xx_DFP v 2.13.0 package ( C:\Keil_v5\ARM\Pack\Keil\STM32F4xx_DFP\2.13.0\Drivers\STM32F4xx_HAL_Driver\Inc) ?
No, it is generated by the Cube tool, based on how you have configured the target.
