Hi there, this is a working piece of code that I have written and I am wondering if there is any way to reduce the overall execution time, number of cycles or maybe the size of the memory in the code.
THUMB AREA RESET, CODE, READONLY EXPORT __Vectors EXPORT Reset_Handler __Vectors DCD 0x00180000 ; top of the stack DCD Reset_Handler ; reset vector - where the program starts AREA 2b_Code, CODE, READONLY Reset_Handler ENTRY num_words EQU (end_source-source)/4 ; number of words to copy start LDR r0,=source ; point to the start of the area of memory to copy from LDR r1,=dest ; point to the start of the area of memory to copy to MOV r2,#num_words ; get the number of words to copy ; find out how many blocks of 8 words need to be copied - it is assumed ; that it is faster to load 8 data items at a time, rather than load ; individually block MOVS r3,r2,LSR #3 ; find the number of blocks of 8 words BEQ individ ; if no blocks to copy, just copy individual words ; copy and process blocks of 8 words block_loop LDMIA r0!,{r5-r12} ; get 8 words to copy as a block MOV r4,r5 ; get first item BL data_processing ; process first item MOV r5,r4 ; keep first item MOV r4,r6 ; get second item BL data_processing ; process second item MOV r6,r4 ; keep second item MOV r4,r7 ; get third item BL data_processing ; process third item MOV r7,r4 ; keep third item MOV r4,r8 ; get fourth item BL data_processing ; process fourth item MOV r8,r4 ; keep fourth item MOV r4,r9 ; get fifth item BL data_processing ; process fifth item MOV r9,r4 ; keep fifth item MOV r4,r10 ; get sixth item BL data_processing ; process sixth item MOV r10,r4 ; keep sixth item MOV r4,r11 ; get seventh item BL data_processing ; process seventh item MOV r11,r4 ; keep seventh item MOV r4,r12 ; get eighth item BL data_processing ; process eighth item MOV r12,r4 ; keep eighth item STMIA r1!,{r5-r12} ; copy the 8 words SUBS r3,r3,#1 ; move on to the next block BNE block_loop ; continue until last block reached ; there may now be some data items available (fewer than 8) ; find out how many of these individual words need to be copied individ ANDS r3,r2,#7 ; find the number of words that remain to copy individually BEQ exit ; skip individual copying if none remains ; copy the excess of words individ_loop LDR r4,[r0],#4 ; get next word to copy BL data_processing ; process the item read STR r4,[r1],#4 ; copy the word SUBS r3,r3,#1 ; move on to the next word BNE individ_loop ; continue until the last word reached ; languish in an endless loop once all is done exit B exit ; subroutine to scale a value by 0.5 and then saturate values to a maximum of 5 data_processing CMP r4,#10 ; check whether saturation is needed BLT divide_by_two ; if not, just divide by 2 MOV r4,#5 ; saturate to 5 BX lr divide_by_two MOV r4,r4,LSR #1 ; perform scaling BX lr AREA 2b_ROData, DATA, READONLY source ; some data to copy DCD 1,2,3,4,5,6,7,8,9,10,11,0,4,6,12,15,13,8,5,4,3,2,1,6,23,11,9,10 end_source AREA 2b_RWData, DATA, READWRITE dest ; copy to this area of memory SPACE end_source-source end_dest END
I am working with The Cortex M3, as long as one of those three things has been made smaller it's ok. Thank you for your help, the changes don't have to be major as long as something changes.
You could easily make the code significantly smaller by using your individ_loop code for the entire data set, and removing block_loop (and the overhead code of checking if data size is not multiple of block)It is an interesting trade off... code size vs performance, especially for devices with limited memory resources available. Your block copy loop is likely faster, but the individ_loop may be fast enough for your needs.
