3 questions on the KEIL usage
I'm a fresh guy on the KEIL, and here are 3 general questions, thanks any masters helping on it.
1. Is it possible to build a library by keil which could be linked in another project, while in this project, the device CPU is different w/ the one of the library ?
    For instance, in the library keil project , its device is stm32L075RZ(cpu type is Cortex-M0), while another project's device is stm32F1xx. In this case, it seems the library could not link in the later project. For my requirements, the library is not  necessary to bind w/ a specific device/cpu, but the KEIL seems not allow this.  Is it way to make the link happen?
2. Is there way to create multiple libraries in one KEIL project ? Or is there any work around ? It is a common thing if using MAKEFILE.
3. The KEIL could create multi-projects workspace. In this workspace, is it possible to bulk changing all projects from one device to another ?
Thanks in advance.
