Hi
I have a problem by implementing a CMSIS Biquad lowpass filter an a Cortex M4 from TI.
The CMSIS FLOAT filter is working but not the fixpoint Q15 one.
It's just a simple 2nd order (1 stage) filter. The coeffs are calculated with Matlab.
Did anybody tried this allready and see an error in here?
The chrip function generate a chirps sinus with an amplitude of +-1.
Thanks in advance
René
// fs = 16000; // fg = 1600 Hz, Butter // [z,p,k] = butter(2,fg/fs,'low'); // sos2 = zp2sos(z,p,k); // Hd = dfilt.df2tsos(sos2); // fvtool(Hd,'Analysis','freq') // coef = coeffs(Hd); // coef.SOSMatrix // ans = 0.0201 0.0402 0.0201 1.0000 -1.5610 0.6414 #define STAGES ((uint8_t)1) arm_biquad_cascade_df2T_instance_f32 IIR; //stucture for CMSIS-DSP IIR DF2 arm_biquad_casd_df1_inst_q15 IIR_16; // a11 und a12 müssen negiert werden float fCoeffs[] = { 0.0200833659619093, 0.0401667319238186, 0.0200833659619093, 1.56101810932159, -0.641351521015167 }; float32_t IIRstate[2*STAGES]; BiquadLP BiQuadFloat(STAGES, fCoeffs, IIRstate); // this calls arm_biquad_cascade_df2T_init_f32(&IIR, numStages_, pCoeffs_, pState_); // a11 und a12 müssen negiert werden // b10, 0, b11, b12, a11, a12 q15_t n16Coeffs[STAGES * 6] = {329, 0, 658, 329, 25576, -10508}; q15_t n16StateA[STAGES * 4]; BiquadLP BiQuadQ15 = BiquadLP(STAGES, n16Coeffs, n16StateA); // this calls arm_biquad_cascade_df1_init_q15(&IIR_16, numStages_, pCoeffs_, pState_, 1); float fFilterIn = chirp.calc_log(); fFilterOut1 = BiQuadFloat.filter(&fFilterIn);q15_t n16FilterIn = (q15_t)(fFilterIn * 16384.0f); // only scaled by Q14 for test n16FilterOutQ15 = BiQuadQ15.filter(&n16FilterIn);
And this is what I get.
The first chart is the chirp signal (fFilterIn).
The 2nd is the output of the float filter (fFilterOut1).
The 3rd is the output of the fixpoint filter (n16FilterOutQ15).
Hello Rene,
thanks for posting this. Can you please create an issue on GitHub: https://github.com/ARM-software/CMSIS_5/issues? This is where we track things like that and where the experts can take a look at it.
Kind regards,
Christopher
Hi Christopher
Thanks for the answer.
I post it at
https://github.com/ARM-software/CMSIS_5/issues/508
Kind regards
