#include <stdio.h> #include <string.h> #include "cmsis_os.h" #include "Driver_CAN.h" // CAN Driver Controller selector #define CAN_CONTROLLER 1 // CAN Controller number #define _CAN_Driver_(n) Driver_CAN##n #define CAN_Driver_(n) _CAN_Driver_(n) extern ARM_DRIVER_CAN CAN_Driver_(CAN_CONTROLLER); #define ptrCAN (&CAN_Driver_(CAN_CONTROLLER)) uint32_t rx_obj_idx = 0xFFFFFFFFU; uint8_t rx_data[8]; ARM_CAN_MSG_INFO rx_msg_info; uint32_t tx_obj_idx = 0xFFFFFFFFU; uint8_t tx_data[8]; ARM_CAN_MSG_INFO tx_msg_info; static void Error_Handler (void) { while (1);} void CAN_SignalUnitEvent (uint32_t event) {} void CAN_SignalObjectEvent (uint32_t obj_idx, uint32_t event) { if (obj_idx == rx_obj_idx) { // If receive object event if (event == ARM_CAN_EVENT_RECEIVE) { // If message was received successfully if (ptrCAN->MessageRead(rx_obj_idx, &rx_msg_info, rx_data, 8U) > 0U) { // Read received message // process received message ... } } } if (obj_idx == tx_obj_idx) { // If transmit object event if (event == ARM_CAN_EVENT_SEND_COMPLETE) { // If message was sent successfully // acknowledge sent message ... } } } int main (void) { uint8_t data_buf[8]; ARM_CAN_CAPABILITIES can_cap; ARM_CAN_OBJ_CAPABILITIES can_obj_cap; int32_t status; uint32_t i, num_objects; can_cap = ptrCAN->GetCapabilities (); // Get CAN driver capabilities num_objects = can_cap.num_objects; // Number of receive/transmit objects status = ptrCAN->Initialize (CAN_SignalUnitEvent, CAN_SignalObjectEvent); // Initialize CAN driver if (status != ARM_DRIVER_OK ) { Error_Handler(); } status = ptrCAN->PowerControl (ARM_POWER_FULL); // Power-up CAN controller if (status != ARM_DRIVER_OK ) { Error_Handler(); } status = ptrCAN->SetMode (ARM_CAN_MODE_INITIALIZATION); // Activate initialization mode if (status != ARM_DRIVER_OK ) { Error_Handler(); } status = ptrCAN->SetBitrate (ARM_CAN_BITRATE_NOMINAL, // Set FD bitrate 10000U, // Set bitrate to 100 kbit/s ARM_CAN_BIT_PROP_SEG(5U) | // Set propagation segment to 5 time quanta ARM_CAN_BIT_PHASE_SEG1(1U) | // Set phase segment 1 to 1 time quantum (sample point at 87.5% of bit time) ARM_CAN_BIT_PHASE_SEG2(1U) | // Set phase segment 2 to 1 time quantum (total bit is 8 time quanta long) ARM_CAN_BIT_SJW(1U)); // Resynchronization jump width is same as phase segment 2 if (status != ARM_DRIVER_OK ) { Error_Handler(); } for (i = 0U; i < num_objects; i++) { // Find first available object for receive and transmit can_obj_cap = ptrCAN->ObjectGetCapabilities (i); // Get object capabilities if ((rx_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.rx == 1U)) { rx_obj_idx = i; } else if ((tx_obj_idx == 0xFFFFFFFFU) && (can_obj_cap.tx == 1U)) { tx_obj_idx = i; break; } } if ((rx_obj_idx == 0xFFFFFFFFU) || (tx_obj_idx == 0xFFFFFFFFU)) { Error_Handler(); } // Set filter to receive messages with extended ID 0x12345678 to receive object status = ptrCAN->ObjectSetFilter(rx_obj_idx, ARM_CAN_FILTER_ID_EXACT_ADD, ARM_CAN_EXTENDED_ID(0x12345678U), 0U); if (status != ARM_DRIVER_OK ) { Error_Handler(); } status = ptrCAN->ObjectConfigure(tx_obj_idx, ARM_CAN_OBJ_TX); // Configure transmit object if (status != ARM_DRIVER_OK ) { Error_Handler(); } status = ptrCAN->ObjectConfigure(rx_obj_idx, ARM_CAN_OBJ_RX); // Configure receive object if (status != ARM_DRIVER_OK ) { Error_Handler(); } status = ptrCAN->Control( ARM_CAN_CONTROL_RETRANSMISSION,0); if (status != ARM_DRIVER_OK ) { Error_Handler(); } status = ptrCAN->SetMode (ARM_CAN_MODE_NORMAL); // Activate normal operation mode if (status != ARM_DRIVER_OK ) { Error_Handler(); } memset(&tx_msg_info, 0, sizeof(ARM_CAN_MSG_INFO)); // Clear transmit message structure tx_msg_info.id = ARM_CAN_EXTENDED_ID(0x02345678U); // Set ID of message tx_msg_info.dlc = 8; data_buf[0] = '1'; data_buf[1] = '2'; // Prepare data to transmit data_buf[2] = '3'; data_buf[3] = '4'; data_buf[4] = '5'; data_buf[5] = '6'; data_buf[6] = '7'; data_buf[7] = '8'; while (1) { if(ptrCAN->GetStatus().unit_state == 1 ) { ptrCAN->MessageSend(tx_obj_idx, &tx_msg_info, data_buf, 8); // Send message if (status != ARM_DRIVER_OK ) { Error_Handler(); } } } }
I wrote it with reference to http://www.keil.com/pack/doc/CMSIS/Driver/html/group__can__interface__gr.html
Such waveforms have appeared before, but the program has been modified
The signal is sent in a loop, which I don't think is correct
Who CAN give me an example of using CAN module correctly to send the simplest message (code that CAN be reused)?
thank you
No one can help me?
jinxinyang,
I'm not sure if you asking for any specific CAN implementation / API issue with your code or your question is just general one.
Have you tried example from "example code" at https://www.keil.com/pack/doc/CMSIS/Driver/html/group__can__interface__gr.html ?
Additionally:Have you tried to see how e.g. mbed is implementing CAN ?https://os.mbed.com/handbook/CAN
Here are some mbed CAN driver sources you can have a look at:
* https://github.com/ARMmbed/mbed-os/blob/master/drivers/CAN.cpp* https://github.com/ARMmbed/mbed-os/blob/master/drivers/CAN.h
With just basic source code navigation skills you can see how mbed sorts CAN out.
kind regardsPrzemyslaw
