ARM V6 ARMCLANG Assembler, Binary don`t run
i want to use ARM V6 for a new project. I try to make a new project in the Keil MDK 5.26 and then switch to ARM 6.10 Compiler. First i leave the assembler on ARMCC and everythings works fine. Debugging was possible.
Then i switch to ARMCLANG-Assembler and change the startup file to a compatible one. But now when i start the debugger, the system hangs here
an my Keil MDK debugger doesn`t react on any key.
Does anybody have an idea?
Best regards
volker
