Hi guys,
I have a little issue, can someone explain me why when i start my project i have a message :
Loading PDSC Debug Description failed for STMicroelectronics STM32F051K6
Disabling usage of PDSC Debug Description
See build Output for détails.
best regards
Hi Martin,
As a first pass I would ask if you have the latest version of the pack installed (v2.0.0)? I do not see any issues with the example project supplied with this pack.Ronan
Hi Roman, as you can see i m currently using the latest version. Did i have to remove the old version ?
You should not need to. Ensure that you have “use latest” selected in this pane
It's currently the last version...
Hello Martin,
which Keil MDK version are you using? Can you make the project available, so that we can take a closer look at it?
Kind regards,
Christopher
Sorry for the long time before my reply
I m using Keil MDK professionnal
i would like but the project is confidential...
