DS5: How to solve autodetect warning message with Platform Configuration Editor?
Hi experts,
     I use Platform Configuration Editor of DS5-v5.27 to generate debug&trace database of a Cortex-A73*4 SOC.
    After autodetect, there are some warning messages about component connections.
     The missing component connections are:
      1. CSTFunnel -> CSATBReplicator
      2. Cortex-A73_0 -> CSETM0
      3. Cortex-A73_1 -> CSETM1
      4. Cortex-A73_2 -> CSETM2
      5. Cortex-A73_3 -> CSETM3
    When I add item1(Funnel->Replicator), the slave list only shows TPIU and ETB, no Replicator is found.
    Item2~5: If I add item2~5 connections, Master CSETM_x only shows "Add Link From This Device", there is no "Add Link to This Device".
    How I can identify the missing connections? or which points I can check cause the issues probably?
   Thanks for your attention!
Best Regards,
Emmy
